pcv valve idea
taka21
363
washington dc
i was thinking if it was possible to add a pcv valve to our pcv system
its just an idea cause im sick of having oil in my intake
if this isnt possible then im just gonna make myself a catch can
i figure this might be a lil simpler tho
any input would be greatly appreciated
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
Sure, you can add a check valve.... but if you install it correctly it's not going to do anything... The purpose of the PCV system is to let those vapors OUT of the engine and remove excess crankcase pressure, not create it; it doesn't take air in.
taka21
363
washington dc
ok
i was just a lil misguided
im just trying to lessen the amount of oil that actually gets into the intake tract so im guessing that the catch can is the only way to clean those vapors before they go into the intake??????
tekdeus
Pronounced Tek-DAY-us
Jan 23, 2006
2,115
Vancouver Canada
www.bitrontech.com
That's right. If your can doesn't have it, be sure to put some stainless steel wool in there with a hose that guides the gases to the bottom of the can to flow back up through the wool. Otherwise the can will be ineffective (i.e. Greddy cans)
CRE
Oct 24, 2005
3,485
Denver, CO
Greddy's catch cans and others built in the same manner aren't ineffective, they're just inefficient. ;) Tek's right though, a couple simple mods can make a big difference.
