PCV system/ explanation and mod
jimi87-t
1,127
5
Colorado Springs
7Mboost;1322617 said:
So I should do this order: cam covers > catch can > intake manifold. Can I just add another port to the catch can and run that to the intake, or would I need another catch can?
If you want to keep both the turbo intake and the intake manifold clean while using the stock setup, you would need a catch on both sides.
But like dumbo said, most of your run time is under vac (non boost) so if you only want one, the one between the covers and the TB would filter out more.
Also guys, the more tubing you add will create more restriction, and lessen the PCVs effectiveness. Don't go crazy with the tubing, check valves etc, trying to add a catch can ;)
Air pumps used for exhaust manifold air injection flow relatively little. The purpose is/was to oxidize residual HC and CO to CO2 and water (steam) in the exhaust manifold. Eventually many manufacturers found that the pulse vacuum produced in the manifold runners as the exhaust valves closed was sufficient to pull air in trhough a lightweight check valve. I believe General Monsters called this "PAIR", Pulse Air Injection Reactor.
In states like NJ, if CO2 in exhaust gas is not close to 14%, the inspectors begin to look for evidence of tampering, which would include dilution of exhaust gas.
BernieK
Mk3runner;1318848 said:
Emissions cheat.. I like it
dumbo
1,911
Albera, Too Far North
tekdeus;1322669 said:
Would a methanol/water nozzle placed before the TB effectively clean any potential oil deposits in the intake manifold from the stock PCV setup?
Or a shot of carb cleaner now and then...Anyways I thought that was the point of a catch can...? Or do you not have one?
IJ, I figured the check valve would be better between the turbo inlet and the catch can in your diagram, then you could get manifold vacum on the crankase? Although I like the idea ending any reverse flow right at the manifold. All and all though, I think your setup is the only properly setup PCV system I've seen on SM. Besides mine:biglaugh:LOL And stockers...But I don't need to tell you that.
Over thinking a simple design:nono:...I'm done haha.
EDIT: Bolded
jdub
Feb 10, 2006
10,730
Valley of the Sun
IJ's diagram is exactly where you want the PCV valve ;)
(you will get manifold vac at all times, except under boost)
dumbo
1,911
Hear me out,
If you don't put the check valve after the turbo inlet then you can never truly get vacum in your crankcase, atmosphere will simply flow in, correct? No matter the volume "sucking" into your TB(Within reason). That is simply fluid dynamics. If you were popping your dipstick out I guess you have no choice, were your lines and fittings from your catch can to turbo of ample size?
Technically speaking, the stock setup can not put a true vacum in the crankcase either, thats why I put the check valve after the turbo on mine.
-10 so yep more than big enough ;)
You slam the throttle shut at the end of a hard pull the BoV's take a second to react and this is enough time to have 0 flow into the Turbo so no matter how big the plumbing is you will pressurise the crankcase.
The only concern I had was introducing pirate air into the intake might have affected the idle mixtures and idle speed (it didn't)
Agreed on no vacuum that's why I think a pump plumbed correctly would be a + if you could find one that a) wasn't noisy b) lasted more than 75 miles before needing a rebuild and c) was able to pull a vacuum in a leaky 7M :)
tekdeus
Pronounced Tek-DAY-us
Jan 23, 2006
2,115
Vancouver Canada
www.bitrontech.com
dumbo;1322714 said:
Hear me out,
I thought about this, until I read that more than 15hg of vac on the crankcase can be bad: http://www.dragstuff.com/techarticles/vacuum-pumps.html
jdub
Feb 10, 2006
10,730
Valley of the Sun
dumbo;1322714 said:
Hear me out,
Unless there is pressure in the crankcase, which there always is some....the vac will pull it in the proper direction. The idea is to get crankcase vapor to either the manifold (which is 90% of the time) or to the turbo intake.
Having said that, a check valve on the intake side that only allows flow in the direction of the intake is not going to hurt anything. And, you are correct...the stock style set-up does not put a "pure vacuum" on the cam covers.
7Mboost;1322730 said:
IJ excuse me as I will be copying your PCV system. :) Thanks.
More than welcome to :)
90T04
Tucson, AZ
www.azsupras.com
I plan on using that same electric pump. Under testing I found that it flows a crap load (exact measurement) of air, and pulls approx 7 inches of vacuum when the intake is blocked off. From what I have read, that is perfect vacuum for a crankcase.
The only problem that I have found is that the pump pulls something like 45 amps of current when first started up, then drops down to around 15 when running. I am planning on running a PCV valve similar to IJ's and then a custom PWM controller to ramp up the power to the pump only under boost.
Here is a link to a previous thread
http://www.supramania.com/forums/showthread.php?t=76560
8,898
jimi87-t;1319044 said:
Not sure if the pump will have any problems even if it does see oil. The Turbo Buick guys don't seem to be seeing any problems, and they have been doing it for a while.
As pointed out by you and others, you absolutely want to evacuate your crankcase. This is why all cars come with it. I am just glad you all want to do so, rather than just 86 it, like the other "emission devices", of which PCV actually increases engine life by reducing sludge.
A little searching outside of this site my be helpful for some ;)
Summit Racing and other retailers have been selling electric crankcase pumps for some time. Crankshafts cost money, even with a sponsor.
jimi87-t;1319815 said:
I did a little research on smog pumps and what they do. Basically they pump air into the exhaust ONLY during warm up, then shut off. This is to aid in helping the extra rich exhaust to continue to burn off the gasses. Once the engine is warmed up they are no longer needed.
Where did you read that? Cars with smog pumps or pulse air are done for the pre cat. Except our car. At least I have never seen Toyota say so. The front cat is for NOx reduction. According to both GM and Ford. Those piece of s*** Chryslers don't count unless it is a Mitsu or Benz.
The precat uses the CO to get rid of the NOx. That gids rid of some of the usable air for the secondary, or main reduction cat. So air is pumped in. What I have seen is switching between pumping air into the head or cat, and sometimes venting. But it will pump to the cat hot and cold.
IJ.;1319524 said:
You actually want it to pull a vacuum, there is quite a large volume of blowby even in a good condition engine so it takes a good pump to keep the crancase in vac.
How you doing old man? :)
jetjock;1322560 said:
No, it isn't. There's very little pressure drop across the air filter and AFM. Nor do you want any. Think about it...
Good topic Jimi. I like your work.
dumbo
1,911
Interesting theory. Although I think that is what the oil pump is for. But I don't want to get into that.
Honestly I don't think I could see that much vacum in the crank with my setup, if you think about the shear volume in there and the size of the TB orifice. Plus at cruise your not pulling as much vacum. I would like to temporalily hook up a vacum gauge and see.
Good point on the BOV IJ, never though about the delay in the opening of it.
Regardless, informative thread, on a system that is grossly misunderstood.:icon_bigg
