pcv hummmmmmmm exhuast or per turbo
Tire Shredder
569
Oshawa
it's my understanding the exhaust dump style pcv system is only effective with high volumes of gas. Since the system works strictly from the venturi effect and not direct vacuum, you need that exhaust volume to pull the gases out of the motor. Granted, this is will keep your intake tract spotless and the most critical time it's needed is at high power/boost/rpm levels (like WOT on a turbo car). So it's great for race cars.
In my opinion you should route it through the normal intake tract if you drive a street car, since it will spend most of it's time at partial throttle with very little gas flow. Most likely with long periods between WOT (like highway cruising) when gases and pressure can build up.
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
the one line goes to the intake manfold wiht one way cheak vavle
so that is part is taken car of but my mian qestion will and exhuast vent all the time or just under hard pulls
or should i do just pertrubo and muck my shit up
WhtMa71
D0 W3RK
Apr 24, 2007
1,813
Macon, GA
From what I've understood, slash cut PCV exhaust dumps only work well when you have an exhaust with no mufflers, cats., resonators..ie they only work well with no backpressure like if you have an open DP. It'd probably be best to plumb it like stock with a catch can with some sort of filter in it like stainless steel wool.
NashMan
Aug 5, 2005
4,940
17
Victoria BC
well i have hardly no muffler
3.5 inc dp and 4 inc dp back to the smallest burn muffler it more like resantore but smaller
so i have lots of volume and dick for back persure
i should have stated this befor
so trubo or exhuast
and ian you short littel msg does not make sence make it littel dumber ps i am drunk heheheh
NashMan
Aug 5, 2005
4,940
17
Victoria BC
well then so i can not run it any were is what you are saying ????
i am fully sober as nune going to church still scarching my head
no to trubo intake pipe
and no to exhuast
remmber this is only for high boost vent off boost is taken care of from my intake manfodl with one way vavle
so far shedder is the only one to say do it like fully stock
but i remmber jet jock listing the turbo it's self has dick for vacume
i just want littel more explaintion really
i done some sreches over time but really get mixed up answers i never installed one befor as in exhuast vent
and i get mixed up answer whe i talk to poeple
ps did any on go to my link to see my setup
if so i got to buy a bittel contaner wiht an fitting so i cam cram some beahter filter matting in it
Ryan: I was reading your question as you wanted to use a race style Exhaust PCV plumbed into either the exhaust after the Turbo or into the header before the Turbo?
My answers were based on this.
I run a proper PCV valve plumbed into a catch can with a small line to the intake and a large line to the Turbo intake and so far it's all as dry as a baone with no Oil pullover.
NashMan
Aug 5, 2005
4,940
17
Victoria BC
ok now we are geting some where what happens if i swap the per turbo for exhuast dump and how much persure does it take to open i got my off boost all covered just wana dump my full boost vapor
Exhaust dumps work on the venturi principle and velocity past the opening, using a muffler slows this to a point where they don't draw enough volume and you end up with + pressure in the crankcase and all the bad things associated.
A correctly designed and built system like I described won't pull crap into the IC so I can't see any reason to use a setup that might not work.
NashMan
Aug 5, 2005
4,940
17
Victoria BC
1 more qestion that a person brought up on another form
you wled the bung and add in tube with anlge cut in it suppost help the venturi afect ?
next you weld the bung on sharp angle in the exhuast this one some guy at the track told me but does nto really make sence sure it will be high persure zone but again i nto to femlier about exhaust dude i never sean one in my life working aka testing it
don't get me wroung trubo pipe is on teh top of my list of it will work fine but an exhuast dump will look pretty clean
NashMan
Aug 5, 2005
4,940
17
Victoria BC
i do have gauge port on my d block that i was plaing on installing to see if had persure build up for when i have it on the dyno to see if there was build up
i chould all way's change it back to the per trubo set up if i had an issue
i wounder if should try it
cause i kinda wanted to run open turbo anyway and if did long trip swap filter on it this is not every day car i am building
thansk for the info too helps alot
NashMan
Aug 5, 2005
4,940
17
Victoria BC
i think this will work if tie it in the waste gate dump pipe with slash cut tube
there is no muffler no nothing no back persue at all
i pretty sure this will work what do you think ij
i gonna seach on the net to see if any one has tried this befor
tekdeus
Pronounced Tek-DAY-us
Jan 23, 2006
2,115
Vancouver Canada
www.bitrontech.com
Ryan, you're best off with a really effective catch can. I'm in the middle of redoing my catch can. It's an older GReddy model and I will add in a 2nd inlet, and polyurethane tubes that will force the gases to the bottom of the can, and it will be stuffed with Bull Dog stainless steel wool, and be bolted to the fenderwell where the cruise control was to be as cool as possible to condense the most oil. I will also have a check valve at the TB port, if I can unclog the damn thing!
NashMan
Aug 5, 2005
4,940
17
Victoria BC
i done that year's ago to my catch can steel wool and tube think i may reaplce it thou since i ahve not reaplces that wool for like um last time i used it like 4 plus yeasr ago
and i never had any issue being where the abs used to be
