Well i think its time to fill you guys in on what i have been up to with my supra. For those who dont know me, my name is pat, and ive been talking with Jay (Suprahero) on here alot. I mostly do alot of reading and learning here, but i feel its now my time to post up the build im working on, and contribute to the forum.
Well, im in the sorta slow process of rebuilding my 91 supra. I figured ide be kind enough to keep you guys updated with the progress... Right now the car sits mostly stock, except for the JDM 1JZ-GTE motor that the previous owner installed.
Right now my parts list is pretty small but it will be growing alot over the period of the next month....
Parts List:
1JZ aluminum flywheel (11.5lb)
ARP flywheel bolts
R154 trans rebuild kit
OEM clutch slave cylinder
AEM Uego wideband o2
Crower 272 cams with upgraded springs and titanium retainers.
540cc Sard Fuel injectors
Aeromotive Fuel pressure regulator
South Bend stage 3 full face clutch kit
ARP head studs
Heavy duty bearing cover plate And poly shifter bushing for R154 trans
Tial 50mm blow off valve
1st gear thrust washer
New oil pressure sender
Stinger Standalone + PnP Harness
ST Sway Bars
Energy Poly Bushings
2JZ oil pump (new)
1JZ power steering pump (new)
Greddy timing belt
Complete 1JZ gasket set w/ headgasket
Nashman Short shifter
DM aluminum pully set
BM 8x11x1.5" oil cooler
Oil filter block block adapter
-8AN steel braided oil lines
T4 turbo oil lines
T4 custom manifold
31x12x3" Intercooler
46mm external wastegate
Parts on the way:
TBA
Heres a pic of the parts i have as of now. I will be ordering more tomorrow or thursday night. Ill keep you guys posted as the list grows.
ARP head studs
ST Sway bars, A1 Endlinks (rear), Greddy timing belt, Energy Poly bushings )front and rear control arms), New Oil pump, New power steering pump.
Regulus type header panel. (sweetness)
Stinger Standalone ECU w/ PnP harness
Parts List:
ARP flywheel bolts
ARP head studs
ST Sway Bars
2JZ oil pump (new)
Greddy timing belt
T4 turbo oil lines
T4 custom manifold
Parts on the way:
TBA
ARP head studs
