I searched but none of the previous issues apply.On my 91 I cant get the passenger door to unlock so I can open it. It has the engine removed so the harness is out but if I hook up a battery I can put the drivers side window down but not the pass. side. The electric lock/unlock wont work and if I try to move the lock lever manually it wont go all the way to the unlock position. I have also tried to unlock from outside and have the same issue with the key as the lock lever. I have the top off so I can manuver a wire hanger down the inside or outside of the window but cant seem to latch onto whatever I need to to unlock and open the door. I have checked the TSRM but am unsure of what I should even be grabbing a hold of. Since the door wont open I cant take off the panel to see what is going on inside. I've been working on this all day with no success. Currently have sprayed some PB Blaster in the key hole hoping to free it up. Would anyone have any further suggestions on how to open this baby. Thanks in advance.
Mike
Mike
