part throttle surge
ImUrTurboLover
9
New Jersey
Hi guys i searched around for a bit with no luck
I've noticed that my supra at low throttle inputs (less than 30% say) the car surges
it'll be slow then all of a sudden surge forward almost in a bucking fashion, but this is when the gear i'm in is already fully engaged
it seems to happen exclusively in low gears 1st and 2nd being the most obvious
but the car is a bit of a handful in traffic I find myself pushing the clutch in more than I normally would. Under boost, or at higher speeds, the car is behaving like it should
any ideas? I was thinking shotty or misaligned TPS...
lagged
1991 1JZ
new rochelle
well it will do that if the BOV is open while accelerating, and when it closes again the car will surge forward like youve described.
