JJ
got a question for you regarding servomotors.
most servo motors used in DBW throttle application get driven directly from the sender motor on the pedal.
There is a car that does not do that. In particular this car has the sender but the signal goes to a CAN bus and that then gets sent to the DBW which in turn turns it into throttle plate position.
So the question is (and I think I know the answer). The servo motor should still be the same as before but now has a CAN reciever module built in. If the schematics are shown. Can the CAN reciever portion be bypassed and have a PID controller directly attach to the DBW motor?
-figgie
-figgie
