I have the Pacesetter Header and I have done so much to make it work....it doesn't look anything like it did originally. First I had to saw off a bit of the front of the flange to clear the water outlet under the dizzy, I then had the slip flange welded together, then where the pipes turn from 2-1 to extend to the cat I cut it and had a flange welded on it and had a custom pipe with a hi-flow cat welded and flanged to mate with the rest of the exhaust system. I had to bore the stud holes for the head flange since it wouldn't slide easily, finally I had an o2 flange welded on ( since the one provided was too far back and I used it for my secondary o2, california emission vehicle.) right where it turns from 2-1. Off to Jett Hot for coating they went and finally on the car. I paid 100 bucks for the headers and over 400 to prep em! I also have the 2.5" Pacesetter exhaust system and together it sounds weird full throttle...kinda like a swooosh rather than a roar, not annoying though.
