I have a 88 Supra turbo, and the past week it has been overheating pretty bad about 5 minutes after it hits normal operating temp. I changed the thermostat today, and the same problem keeps happening. Any ideas would be appreciated.
David Geiger;1595129 said:Have you checked all your hoses? Make sure none of them are ripped or tore or popped. Also make sure your clamps are down good. Also check to see if your radiator cap is still working properly.
89supra7mgte;1595624 said:Pull radiator cap and start car if it shoots a stream you have bhg, time for rebuild.
