I got such good info on my last question I figured I'd try another!
1990 turbo supra, A/T, stock.
When the weather warmed up this summer overheating problems reared their heads.
What I did: New fan clutch, (tundra orange hub) rad re-core, new 180 thermostat, new 13psi cap, and while I was at it I replaced all hoses that looked funky, especially those ones you can't get at easily.
The rad I had re-cored was the one that was in the car when we got it, and it is not stock, it's a brass tanked two row job.
There is no auxillary trans cooler, just the one in the rad.
The air conditioning does not work, so there is no extra heat load there, and I've straightened fins/ cleaned core on the condenser and IC.
The head gasket does not leak, the car loses no coolant.
The fan shroud and engine undercover are there.
The above listed repairs dealt with the heat problems, mostly.
The reason I say mostly is because there is a hilly road I use for cooling system testing, and the car still fails on it. The road is two lane, very steep, long, and full of hair pins. So, lower speeds, on and off boost, but more on than off. After about ten minutes of this the temperature starts to climb.
It's a piss-off pulling over to cool while watching rusted out old chevys with V8's cruise by pulling hard with no issues. I'm considering getting the biggest aluminum rad I can stuff into the thing, but instinct tells me I'm missing something; the car should not overheat on an 80 degree day in stock configuration with stock cooling system.
What I'm looking for is someone's real world experience with a similar car in a similar situation.
In the owners manual they tell you to avoid long periods of boost or risk overheating, however I do not see how you can avoid long periods of boost on a road like the one I'm using as a testing ground.
