is there a sure way to find out its the temp sensor? easiest way possible
8 88tsupra Guest Apr 24, 2005 #21 is there a sure way to find out its the temp sensor? easiest way possible
I IJ. Grumpy Old Man Mar 30, 2005 38,728 0 0 62 I come from a land down under Apr 24, 2005 #22 Borrow one from a friend or a parts car?
8 88tsupra Guest Apr 24, 2005 #23 ok this may seem like a dumb quesiton but where is hte temp sensor is it one of the ones near the thermo housing?
I IJ. Grumpy Old Man Mar 30, 2005 38,728 0 0 62 I come from a land down under Apr 24, 2005 #24 It's the single wire sensor on the side of the T Stat housing it has a rectangle plug.
8 88tsupra Guest Apr 25, 2005 #25 ok by bro just said it cant be the temp sensor because when the car is parked it boils the water in the rad and shoots steam into the overflow bottle.
I IJ. Grumpy Old Man Mar 30, 2005 38,728 0 0 62 I come from a land down under Apr 25, 2005 #26 88tsupra said: ok by bro just said it cant be the temp sensor because when the car is parked it boils the water in the rad and shoots steam into the overflow bottle. Click to expand... That there is a pretty important piece of info! Go grab a test kit for a BHG
J JT87NA New Member Mar 30, 2005 171 0 0 43 SLC, UT Apr 25, 2005 #28 88tsupra said: whats the name for the test kit :icon_cry: ? Click to expand... Block tester, if you read my previous post it explains the info. Later.
