Over Heating
Nightshift
Corpus Christi
When I Purchased my supra I drove it all the way back to Corpus "My home Town" about a 250 mile drive. My buddy drove it home and it run perfect. My plans for it are to drop a 2JZ into it, eventually after I come up with the money.
But right now I just want it to stop over heating. On the trip there was no over heating what so ever, but now as I drive it. It is over heating within 10 minutes of driving, Can’t tell if water pump needs replacing or radiator or the fan clutch. But here are the pictures in order.
http://i205.photobucket.com/albums/bb246/surferclay/ImportedPhotos00103-2.jpg
http://i205.photobucket.com/albums/bb246/surferclay/ImportedPhotos00104-1.jpg
http://i205.photobucket.com/albums/bb246/surferclay/ImportedPhotos00110.jpg
http://i205.photobucket.com/albums/bb246/surferclay/ImportedPhotos00113.jpg
http://i205.photobucket.com/albums/bb246/surferclay/ImportedPhotos00114.jpg
http://i205.photobucket.com/albums/bb246/surferclay/ImportedPhotos00116.jpg
http://i205.photobucket.com/albums/bb246/surferclay/ImportedPhotos00117.jpg
http://i205.photobucket.com/albums/bb246/surferclay/ImportedPhotos00118.jpg
http://i205.photobucket.com/albums/bb246/surferclay/ImportedPhotos00119.jpg
http://i205.photobucket.com/albums/bb246/surferclay/ImportedPhotos00120.jpg
http://i205.photobucket.com/albums/bb246/surferclay/ImportedPhotos00121.jpg
http://i205.photobucket.com/albums/bb246/surferclay/ImportedPhotos00122.jpg
http://i205.photobucket.com/albums/bb246/surferclay/ImportedPhotos00123.jpg
If You have ANY ideas what could have caused it or "WHAT I CAN DO TO FIX IT" Thank you
If you need more pictures just ask!
prism1
prizmosis jones
May 24, 2006
203
fresno
the only thing i can sugest is replace the radiator cap.
burp the cooling system
change out the thermostat
and check the raiator for leaks
its usually one of those problems
dustin
ForcedTorque
Join the 92 Owners Group
Jul 11, 2005
6,099
Best advise I could give is to have a compression test done BEFORE you spend a bunch of money replacing parts. These cars are notorious for Blown Head Gaskets (BHG).
You should buy the car a fan shroud to take full advantage of the fan.
I once bought an 87 that looked almost exactly like yours, and had the same 1 week before mine started overheating. Mine was BHG, but that doesn't mean yours is. The only sure thing is, if you keep driving it, it will be. Get the overheating figured out IMMEDIATELY! It only takes one good overheat to warp an aluminum head.
BTW..........Welcome to the site. It was refreshing to see you thanking the community for letting you in. Your car is very nice! Stick around a while, and this community can be very helpful to you.
AJ'S 88NA
2,419
Florida
The radiator looks like it's seen better days which means the rest of the system is probably the same. How's it look inside the radiator? Don't know if it would help to flush out the system with a radiator flush, then maybe change out the thermostat and cap. Check for leaks and fill with 50/50 anti, see what happens. You don't want it going hotter than what the pics show.
Nightshift
Corpus Christi
The radiator looks like it needs replacing, I will have to anyways if I put I turbo engine in it. Its rusty inside. What radiator (brand, Size, want to buy one soon to get this fixed) would yall suggest I install if I did put a 2jz in it.
And I am from texas so i do say Yall! :)
Nightshift
Corpus Christi
Thank you for the support guys, tonight I am going to try to make it to a friends shop, see what we can do there. NEW Problems Just sitting with no throttle the oil pressure is around 10 or 5 though when given gas moves to 30 or 35. Normal , or no. One of my buddies with a 300zx is helping me on this project and says that it should be more like 20. And there’s more after over heated I turned off. Then let it cool of and start again, it started very badly with the engine not idling good then I turned off and started again and it would not start for two tries. Then had to give it a good amount of gas to keep from dieing.
Again Thank you for your time guys
brad92t
186
Lexington, KY
www.haxors.us
No, 7m idle oil pressure is only rated at 4 psi. Not an issue. (I am sure someone will correct me if n/a is different but I know this to be true on turbos)
bluedragon17
87 NA-T baby!!!
Sep 14, 2006
382
Vacaville, CA
get a leak down test done. It will tell you ALL kinds of things wrong with the motor where it leaks from and any potential issue with the motor......Good luck and hopefully its not a::bhg::
Nightshift
Corpus Christi
Thank Yall So Much,
It was indeed the radiator cap. Gasket did not seal all the way causing the overflow to shoot out the coolant; and empty it all out. Since I had no coolant it overheated very quickly and cooled off very fast.
I just have to say, I love this car. oh and added k&n air filter, And working on primering headers and buying gasket.
