hey guys, i just installed an osgiken triple on my car, went ahead and bled the system with the new slave cylinder, and for one, it feels like pushing against a wall, pedal is stiff as hell.
pedal currently has about 1" of travel before engaging the system.
problem is, i cant get the car in gear while running, with the pedal all the way to the ground. although it goes into gear fine while off, if i leave it in gear, push the pedal down, and try to start it, it just jumps.
i realize this means the clutch isnt disengaging, but will that 1" of play on the pedal make up for it? also the OSGiken has an adjustable ball thing on the slave rod (ya that sounds messed up, cant think of another way to put it) that i can probably use to put the throwout closer to the pressure plate to start off with.
if anyones got some ideas, let me know
