One more MHG Thread - Yikes!
gottadiesel
Flyin Low
Feb 16, 2009
459
Vancouver, Washington
Yeah true with the JE pistons I can see maybe not being an issue, but I am using stock and I believe they come out about 0.020" above deck, so would surely interfere I would assume.
HKS seems to only put out 86mm and Driftmotion description says up to 86mm bore, which I would deduce that means it can be less, regardless of how less down to stock...
Further thoughts?
toyotanos
What will we break today?
2,842
Coon Rapids, MN
I went with a cometic 84mm for my JE .020 over pistons. Looked good when I set it in place and wasn't too thin between the cylinders, either.
I believe Rich (SIP Racing) has 84mm headgaskets and in a slew of thickness too.
