ma71supraturbo said:I was hoping your displeasure with the spool was a tuning issue rather than a turbo issue as the SP61GT is a small to mid-sized turbo. With your fuel mods it is common to run too rich, but you're about normal. You could probably go a bit leaner, but without a way of monitoring knock I wouldn't recomend it. (Leaner of course is hotter, and heat drives the turbo helping spool it). The other main issue is the stock cat-back. When you are running with the cut-out open, is the spool still unacceptable?
For me it is, I know I could lean it out a bit more but I do tend to be a bit more conservative.
I guess for me it is more about the powerband. I have a 2 stroke street bike (don't see many of those around) and it sux until about 6K or so, then it goes like hell. Redline on that is 9.5 or so.
I lost about 1.K of powerband. When you only had 3K of PB and then go down to 2K of PB it is a major difference.
Thanks for the interest though.
Dan
