The new setup is a powerglide. The burgundy car had a th350 (both the pg and the th350 have the same final ratio so both woudl run out of gear at the same time). the first track run i only did a 1/8 mile full throttle and then got on the brakes at about 800 feet or so because i didnt want to get kicked off the track yet. Once i knew the track was hooking i went all out on the second run, and got kicked off the track right after that 10.55 pass.
The turbo i used on the burgundy car was a DBB turbonetics T61, i got 28psi by about 4200 or so IIRC.
