wtf I didnt realize there was more than one I guess.
The TSRM lists only the "fuel pump relay" and the circuit opening relay, and the TEWD shows the FP Control Relay as the same location as the "fuel pump relay". Are these just interchangeable names?
This is the FP relay that I tested (but it only has 4 connectors)
I was going to test the wiring from the fuel pump to the relay tomorrow but I guess if I'm messing with the wrong relay I'll wait. But at the same time, with the above pictured relay unplugged the fuse did not blow, so something is going on with it, or the wiring behind it, right???
Thanks so much for your patience and continued help, I'm so freaking weary and confused....
