Old gas sitting in tank for over a year
tekdeus
Pronounced Tek-DAY-us
Jan 23, 2006
2,115
Vancouver Canada
www.bitrontech.com
My build took an extremely long time and I am planning to drain and get rid of the 1/3 tank of gas that's been sitting in the tank. I believe the previous owner of my car vented the tank to atmosphere as I could ocassionally smell gas around the engine bay. I am concerned that it may have evaporated a fair bit.
A friend of mine said that this gas could have deposited gum and varnish in the tank and said to add Toluene to flush it out. What's the best thing to do here? I plan to drain the gas out, but should I add something first and shake it around?
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
gas for 1 year no issue at all more then one year like 2 mabey i whould take extra care and flush
but yae drain refiill
if you have rooten tank then new fule filter
done many times no issue
VanSupra
Van,B.C.
Brad, old gas smells like varnish and you'll know it's off right away. Dump it if it is. As IJ said dump slosh repeat.. Also spend the $35 for a new filter and replace the older unit while you're in there. Did you find the rear qaurter glass you were looking for?
As gasoline is a mix of many components, some will evaporate faster than others. After a year of sitting and venting it may have vented off all the additives that make it safe for your engine.
This is especially harmful with them using ethanol as the main octane booster now as it's the first thing to evaporate...
ninja6o4
57
Surrey, BC
I never knew that.. I've always just mixed/filled it with 94 and then drove like a granny for that tank.. on next fillup I knew I had all good gas and was ready to rock! :D
mirage83
457
Georgia
If the tanks been vented the entire time it's almost a guarantee that rust has set in as well as the gas itself breaking down. According to how bad it is, you might have a fair amount of rust in there, including on the pump bracket and even on the pump depending on who manufactured it. That's how mine was when I bought it. So I would personally recommend draining them dropping the tank to take a serious look at how it looks inside when you replace the filter. A bunch of loose rust particles in the tank can accumulate on the filter after you refill the tank and drive around, meaning you'll have to go through the whole process again... drain, drop, replace filter, etc.
Another concern (as if anyone who owns a supra needs another one) is that the injectors could be gummed up as well. Depending on how bad they are, you might have to spring for a good cleaning.
suprahabsfan
Boost Addict
Sep 28, 2007
328
Sylvania, OH
Mine was sitting for 1 year and 3 months, with 1/4 tank. I took a 5 gallon gas tank and bought 93 octane gas, and made a couple trips to gas station to completely fill up the tank. This diluted the "bad" gas. After the first tank I changed the fuel filter. No problems here. Seeings as this is not the right way to do it, I would reccomend draining tank like IJ said, but I just didnt have the resources to do it at the time. Most likely all that will happen if it was bad gas is your filter will clog and you'll have to change it.
ninja6o4
57
Surrey, BC
I suppose I never had a problem because my old gas wasn't vented.. I just made sure to avoid boost when it came time to drive on that tank again..
