pbasil1;1119398 said:I dont know much about empire. I guess its a possibility that they buy direct from US amps, though im pretty sure US Amps doesnt do that. I personally own this amp, and i am pretty happy with it. It has suited my needs well, but im in need of a bigger amp with a better freq. response. Im looking hard into the big Audison monoblocks, or the AX line from US Amps. I really want a Class A or A/B mono block, just dont have the cash right now cause these damn 1jz's are so damned expensive to fix up!
These amps are expensive. A good amp will never be chaep, and infact can often times be the single most expensive part or a system. A poor amp will cause you nothing but trouble.... It will likely clip and fry the speaker, which happens all too often, and the less knowledgeable people think its just cause the amp is too powerful. When really it was either too small or just of very poor quality. Invest in a quality amp, and you have a good amp for life. Plus it will give you room to grow with your different tastes. It will have ample power for spl if you wish, or you can run it smoothly in an sq setup.
Investing in an amp is like investing in a strong bottom end before you bolt on a large single turbo. If you have a weak bottom end, then thats the bottleneck of the system and will fail or cause other failures, but if you invest well, it will out live all other parts, and serve you for years to come.
When younger I had alot of problems with amps, Fried a few subwoofers... Always said $hitty subwoofers... Even thou I was not using bad ones... Just your good oh Kicker comps... Even CVR's... Took me a while to figure it all out. I heard from a buddy once that empire was made by some guy with other compony and that he even knew the owner of the compony, said they were American amps but I was not paying attention nor did I care at the time. I dont know what he ment by American amps... I have banged a 2,200 watt max Empire amp = to wut? 300 rms maybe? and I have been absolutely delighted with it... It has powered everything I have thrown at it... Good oh Buddy Matt(A true car Audio expert) said that baby could power 4 of my pr's and not break a sweat... I would use that amp for vx's in confindence, but in that case.... Look at this Beachsupra
http://www.amamax.com/fshememsialc1.html
http://www.amamax.com/fshememsialc2.html
The empire amp's are alot cheaper, yet have one of the most simple designs.. but make up with reliability and power... Hifonic amps arent bad and I doubt they will blow those Vx's... But you should do your homework online on those hifonic amps... Search reviews, see wat kind of subwoofers people match emm with... Even youtube emm, w/e to get your info... Power Acoustik makes Good looking and more then Decent amps... Ill post some links to Power Acoustik amps l8r...
