CajunKenny;1694131 said:
You really need to do some reading before you start in to this. It isn't a good idea to "Learn as you go" with this.
I have a HUGE thread on fullthrottletech.com that will take you through my experience all the way from running the maft in AFC mode to a full speed density tune.
i read that last night
it was a lot of really good info thanks
i also read everyting i could find on the maft pro in my car... your thread was the most useful
and thanks for the reply i will do as you have suggested
my only problem is i dont have an extra bung to put my stock o2 sensor in so i was wondering if i can take the narrowband signal from the alternate output on my lambda and tap it into the o2 wire on my stock ecu or do i actually need the stock o2???
if i do need the stock o2 sensor where is the best place to get a bung??
thanks again
---------- Post added at 05:32 PM ---------- Previous post was at 05:22 PM ----------
so will this be the correct bin to run???
Source File: TUNE.bin
Source Definition: TPro500 Vehicle0 and 1.xdf
Constants
Vehicle Select 00
Number of Cylinders 6
Displacement 3.00 Liter
Airflow Source 0x00 Select
Manifold pressure source 00
Load Source 0x00
Barometer Comp Mode 01
Frequency Out Mode 0x04
V Out1 Mode 0 Select
V Out2 Mode 0 Select
AFR Source 1 Select
Freq In Mode 0
Aux 1 mode 00
Main Scale 0.00
Volts Out 1 Limit 2.51 limit
Volts Out 2 Limit 3.61 volts
Afterstart enrichment 0.00
Tune Load Point, Low 36.40
Tune Load Point, Mid 100.10
Tune Load Point, High 143.00
Freq Out Max 0
Timing Monitor, Base Adjust 0.00
Timing Monitor, Correction 1.27
FE Smoothing 30
SparkBase 15.00 degrees
Boost control TPS Spool 2.50
Boost control RPM Spool 2400 RPM
Boost control TPS Start 3.70 Volts
Boost control PSI Start 5.00 PSI
Boost control DC% Start 10.00 Percent
Boost control PSI Set 10.00 PSI
Boost control PSI Aux 10.00 PSI
Boost Control Gain 4.00
Boost Control DC% Start Aux 10.00 Percent
Boost Control Max RPM 0.00
AFR Min TPS 4.90
AFR Min RPM 3200
AFR Min Load 166.50
AFR correction lean limit 10.00
AFR correction rich limit 10.00
AFR correction gain 4.00
AFR Aux % 0.00
AFR Tracking, Enable delay 0.00 Seconds
TPS Enrichment 0.50
TPS Decay 0.80
Throttle Body Size 7
TPS MAP Max 104.06
MAP Enrichment 0.40
Boost Enrichment 0.10
MAP TPS Min 0.40 Volts
MAP RPM Min 2560.00
MAF Limit TPS Threshold 0.00 Volts
MAF Limit 0.00
MAF Limit / KRPM 0.00 Grams/Sec
MAF Limit RPM Min 0.00 RPM
MAF Limit Time 0.00 seconds
Part Throttle Tracking Idle TPS 0.00
Part Throttle Tracking Idle A/F Ratio 0.00
Part Throttle Tracking Idle RPM 0.00
Part Throttle Tracking Cruise TPS 0.00
Part Throttle Tracking Lean Load 0.00
Part Throttle Tracking Cruise RPM 0.00
Part Throttle Tracking Cruise Load 91.05
Part Throttle Tracking Cruise A/F Ratio 0.00
Part Throttle Tracking Lean Delay 10.00
Part Throttle Tracking Lean A/F Ratio 0.00
Part Throttle Tracking Gain 12.20
Part Throttle Tracking Startup Delay 74.51 Percent
Enhanced TPS RPM threshold 4800.00
Enhanced TPS Load Threshold 188.24 KPA
Flags
Tables
VE table
MAP(Kpa) RPM
00 400 800 1200 1600 2200 2800 3400 4000 4600 5200 5800 6400 7000 7600
320 81.0 80.0 80.0 83.5 86.5 90.0 91.5 86.5 86.5 85.5 84.5 83.0 82.0 81.0 81.0
300 80.0 80.0 80.0 83.5 86.5 90.0 91.5 86.5 86.5 85.5 84.5 83.0 82.0 81.0 81.0
280 80.0 80.0 80.0 83.5 86.5 90.0 91.5 86.5 86.5 85.5 84.5 83.0 82.0 81.0 81.0
260 80.0 80.0 80.0 83.5 86.5 90.0 91.5 86.5 86.5 85.5 84.5 83.0 82.0 81.0 81.0
240 80.0 80.0 80.0 83.5 86.5 90.0 91.5 86.5 86.5 85.5 84.5 83.0 82.0 81.0 81.0
220 80.0 80.0 80.0 83.5 86.5 90.0 91.5 86.5 86.5 85.5 84.5 83.0 82.0 81.0 81.0
200 80.0 80.0 80.0 83.5 86.5 90.0 91.5 86.5 86.5 85.5 84.5 83.0 82.0 81.0 81.0
180 80.0 80.0 80.0 83.5 86.5 90.0 91.5 86.5 86.5 85.5 84.5 83.0 82.0 81.0 81.0
160 80.0 80.0 80.0 83.5 86.5 90.0 91.5 86.5 86.5 85.5 84.5 83.0 82.0 81.0 81.0
140 80.0 80.0 80.0 83.5 86.5 90.0 91.5 86.5 86.5 85.5 84.5 83.0 82.0 81.0 81.0
120 80.0 80.0 80.0 83.5 86.5 90.0 91.5 86.5 86.5 85.5 84.5 83.0 82.0 81.0 81.0
100 80.0 80.0 80.0 83.5 86.5 90.0 91.5 87.0 86.5 85.5 84.5 83.0 82.0 81.0 80.0
80 73.0 73.0 73.0 78.0 83.0 86.0 89.0 87.5 85.5 85.0 83.5 83.0 82.0 81.5 81.0
60 69.0 65.0 65.0 70.0 74.0 78.5 85.0 86.5 84.5 84.0 82.5 82.0 81.0 81.0 81.0
40 61.5 59.0 59.0 61.0 63.0 67.0 78.0 82.0 78.5 77.5 76.5 75.0 74.0 74.0 74.0
20 54.0 51.0 51.0 54.0 56.0 60.5 69.5 73.0 69.5 67.5 66.5 65.5 65.5 65.5 65.5
00 47.0 47.0 47.0 50.0 52.5 56.5 61.0 61.0 59.0 57.0 56.0 55.0 55.0 55.0 55.0
AFR Tracking
AFR AFR
2000 3000 4000 5000 6000 7000 8000
A/F Ratio 0.00 0.00 0.00 0.00 0.00 0.00 0.00
AF User Tune Hi
RPM
Percent 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0
AF UserTune Mid
RPM
AF User Tune Lo
RPM
Aux Triggered tune
Percent 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00
Air Temp Correction
degrees
-40.00 13.00 41.00 62.00 82.00 103.00 129.00 173.00 315.00
Pecent 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00
Spark WOT
RPM
2000 2500 3000 3500 4000 4500 5000 5500 6000 6500 7000 7500 8000
Degrees 15.00 15.00 15.00 15.00 15.00 15.00 15.00 15.00 15.00 15.00 15.00 15.00 15.00
Spark Aux
RPM
Custom Voltage MAF
Volts Grams/Sec
0.25 2.58
0.50 3.97
0.75 5.30
1.00 7.42
1.25 10.63
1.50 14.91
1.75 20.00
2.00 25.59
2.25 31.47
2.50 37.67
2.75 44.66
3.00 53.38
3.25 65.55
3.50 83.72
3.75 111.45
4.00 153.47
4.25 215.83
4.50 306.04
4.75 433.21
4.75 433.21
4.75 433.21
4.75 433.21
4.75 433.21
4.75 433.21
4.75 433.21
4.75 433.21
4.75 433.21
4.75 433.21
4.75 433.21
4.75 433.21
4.75 433.21
4.75 433.21
4.75 433.21
4.75 433.21
4.75 433.21
4.75 433.21
4.75 433.21
4.75 433.21
4.75 433.21
4.75 433.21
VE Table MAP axis
KPA
(null)
(null) 320
(null) 300
(null) 280
(null) 260
(null) 240
(null) 220
(null) 200
(null) 180
(null) 160
(null) 140
(null) 120
(null) 100
(null) 80
(null) 60
(null) 40
(null) 20
(null) 00
VE RPM Points
1 2 3 4 5 6 7 8 9 10 11 12 13 14 14
(null) 0.00 400.00 800.001200.001600.002200.002800.003400.004000.004600.005200.005800.006400.007000.007600.00
---------- Post added at 05:33 PM ---------- Previous post was at 05:32 PM ----------
and at what point should i install the maft boost controller???
