Oilllllllll Problemmm Leaking Helpppp
supramacist
1,501
The Grassy Knole
clean it up with some....., castrol super clean, purple bottle. Available at any parts store. A little bit of this shiat and a toothbrush will go a long way. Then just got to the car wash....., and turn the hose on her. Just make sure you leave it running.
Toyotaxtreamteam
231
Mass
is it possiable if it was the valve covers it could get into where the timing belt is, like inside the cover i have a light film inside but i still dont belive its the gasket, also i went though alot of things today and found alot loose like oil pan bolts
shaeff
Kurt is FTMFW x2!!!!
10
Around
the reason you want stainless steel, for those of you who don't know, is because aluminum (the metal our heads are made of) likes to react to different metals. if you stick a bolt in there that's not stainless, chances are, you'll get some nasty corrosion, and have a hell of a time getting them back out if need be.
-shaeff
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
shaeff said:
the reason you want stainless steel, for those of you who don't know, is because aluminum (the metal our heads are made of) likes to react to different metals. if you stick a bolt in there that's not stainless, chances are, you'll get some nasty corrosion, and have a hell of a time getting them back out if need be. shaeff
Shaeff, two words: "galvanic scale". SS and Al are at the opposite ends ;)
You also might want to look here: http://tinyurl.com/qe5sj
johnathan1
Supra =
Aug 19, 2005
5,056
you don't have to take anything off, there is one cap in front of each vavle cover, just behind the cam sprocket backing plate. You will have to lift up the wiring harness that goes accross the front of the engine, but no big deal...Tighten up those bolts...
