Oil weight and bearing clearances?
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
well i am in the mist of doing this right now
i plan to run http://www.amsoil.com/storefront/tro.aspx
but i haven hard time thinking of what bareing cleance's to run and how much you persure will rise once the turbo oil filter monte removed then comes on how much to shim the pump if needed
plan to run -10 lines as well though out
the reson my last bareing got wiped and were to toyota spec's
bluedragon17
87 NA-T baby!!!
Sep 14, 2006
382
Vacaville, CA
i know nothing about bearing clearances except that basics are you need .003 of clearance for every inch of raceway. but from what ive been told and learned about oils(lube tech) AMS oil is the greatest synthetic out on the market today. Supposedly its been tested against all the other major sythetics and it came out on top above Mobil 1, Royal Purple, Castrol syntec, and Pennzoil synthetic. I had test results somewhere but i cant find them il attempt to locate them but no guarantees
NashMan
Aug 5, 2005
4,940
17
Victoria BC
oh it is good oil but i kinda don't like the idea of haven 20 weight oil cold the 50 part is fine mabye if ran acusump this whould fix the issue i don't wana have and that is harsh start up
see IJ is lucky to get 10 60 where he is that nice oil weight for our cars in mine pending if you cleances are up the the weight change
Doward
4,245
Alachua, FL
I'm running .0020" clearances, aiming for 700rwhp sustained, running 5w30. (will adjust oil viscosity to get the desired oil pressures)
90T04
Tucson, AZ
www.azsupras.com
What is the reasoning behind running your clearances a little loose, if you dont mind my asking Doward? The factory standard is 0.0008 to 0.0021 on the rods and 0.0012 to 0.0019 on the mains, and I have heard people suggest building to the tighter end of the toyota specs.
arz
Arizona Performance
Nov 14, 2005
955
Mesa, AZ
www.ArizonaPerformance.com
Hey is your motor running already? I went with .0018 in this motor or as close to it as I could get, two are a hair over like .00185 (close as I could tell they didnt seem to be a full solid .0019) and one at the middle with the shortest run from the filter is a hair tight. I didn't plan it that way it just worked out that way, I am happy so far, I will let you know what it looks like next time its apart. :icon_bigg
If its any consolation, all I do is road trips and beat the piss out of it. Oil pump is shimmed 9mm IIRC and the cooler bypass goes straight back to the pan without a cooler (this is in the Z) haven't made time to install a cooler yet.
I would say you might want to tune the pressures with the oil cooler bypass if you decide to keep it. Or just make sure to let it warm up.
jt2ma71
Impeller Head
Washington State
NashMan;918342 said:
650 sustained for now bouch of rev limt wheil side ways or heavy loads
plus hard hitting nos
If i were to run my motor this way, I'd set my bearing clearances loose but still within specs and use 15/50 oil and maybe even 20 50. Synthetic of course. Also, too much hot oil pressure can cause pitting on the bearings, so I will make sure i have an adequate oil cooling system and limit my maximum oil pressure to ~70-75 psi
NashMan
Aug 5, 2005
4,940
17
Victoria BC
i gonna be runing a rx7 base oil cooler so the cooling part is good to go
going to be runing bigger line's -10
ditch stock filter monte and plug stock hole
drill block -10
oil line -10
as for shimming not sure yet ?????
oil to try to run whould be 50 weight of some sort (hot)
most likly a oil prime setup since the cold weight will be to heavy for my likeing
and relocated filter cause the stock one will no longer be used
i have bena on some rx7 forums and they say the oil t state is 180 or 190 or some thign noter sure get mixed up answer's kinda wana know for sure
or shoudl i just drop this idea
jdub
Feb 10, 2006
10,730
Valley of the Sun
Nash - the motor I'm working on will have the bearing clearances at mid-spec and I'm going to run a 0W-30 syn oil. One thing to keep in mind about oil is the 1st number is not accurate concerning viscosity cold...it is relative when comparing viscosities between oils. Cold viscosity on the 0W-30 (German Castrol) I'm using is around 70 cst at 40 deg C (if you want to call that cold)...that is nearly 6 times thicker than the same oil is when at ops temp. Motor oil ALWAYS drops in viscosity (thins) then it gets hot. Eneos 0W-50 has a cold viscosity of 104 cst...1.5 times that of the above 0W-30. Thick oil does not flow well cold and flow is what keeps your bearings from touching.
Before you decide to use the heavier weight oils, read this and make your own decision:
http://www.supramania.com/forums/showthread.php?t=41775
(Also read the oil link in my sig)
And this thread compares Eneos to other syn oils available:
http://www.supramania.com/forums/showthread.php?t=54294
If you want to run a thick oil, you'll need to run your clearances on the loose side of spec to get the flow you need...especially cold.
Adjuster has an RX7 cooler...shoot him a PM on the thermo opening temps.
Doward
4,245
Alachua, FL
Andy, not yet :( School + Work = no time to get things together. Hey, I haven't even had a chance to order my oil pump supply kit from you, so you KNOW it's not done yet! ;)
I went loose on the TSRM specs, because I plan to run more oil than stock through the system. Also, tight clearances to not lend themselves toward running very high hp (think about how much force you need on a piston, to make a 3.0L motor make 600+rwhp) especially with a thick oil.
I'm going to breakin on 30 wt and go from there. With .0020" mains/rods, depending on how the new oiling system goes, I may find myself on a 40 weight oil ;)
jdub
Feb 10, 2006
10,730
Valley of the Sun
I'd be more inclined to run a 40W on a high HP motor built with the clearances a bit more loose. There's a couple out there that would be a good compromise on the cold flow side. Actually, the German Castrol is a heavy 30W...getting close to a 40W at ops temp.
I'm not shooting for HP numbers that high or RPM over stock.
Debris in the bearings...yes. From 210 deg F oil at the pressures the 7M pump is capable of...no.
jdub
Feb 10, 2006
10,730
Valley of the Sun
Doward;919162 said:
Jdub, would you mind looking up the cst values of Redline 10w40 and 5w30? (I'm in ChemII right now, lol)
Red Line 5W-30 62 cst @ 40 deg C...10.6 cst @ 100 deg C
Red Line 10W-40 93 cst @ 40 deg C...14.6 cst @ 100 deg C
jt2ma71
Impeller Head
Washington State
I am also running tight clearances on my 2j, within spec. I have been running it with castrol 5w30 and will switch to amsoil 5w30 after ~500miles. All oil lines are -12, with mocal 180 thermostat and 25 row cooler. I don't plan on running it the way Nash will run his. If I did, I would have set my clearances on the loose side and use thicker oil. With the 5 stage dry sump system, oil pressure is almost instantly up as soon as motor is cranked over. Ron
Doward
4,245
Alachua, FL
Awesome, thanks jdub - I'm planning on this:
1) Initial fire up on straight 30wt
2) First 500 on dino 10w30 (probably Mobil's stuff)
3) If my oil pressure is looking good on the 10w30, I'll switch over to 5w30 Redline.
OR
3) If my oil pressure seems a little low, I'll switch over to 10w40 Redline ;)
