I have a 91 7M all stock, but i did install a full flow oil cooler setup but i did not install a thermostat. I know i need to add one in there, im not looking to get blasted but i would just like to better understand what it actually does. With not running one at the moment, what negative things can happen to the engine? Id just like to know what regulating the temperature of the oil does in both positive and negative forms. I believe what Jdub is putting out is correct concise material just want to better understand how everything works together. Thanks!
