I'm putting an oil temp gauge in my Supra and I was wondering if anyone had any suggestions on where to locate the oil temp sender that came with the gauge?
shaeff said:hey suprabad, long time no see! welcome back.
when i hook up my oil temp gauge, i'm going to drill a hole in the drain plug, and locate it there. (always in the oil)
-shaeff
-shaeff
Thats what I use for oil temp/pressure, mine doesn't quite look like that (that must be an older one or something) but its the same thing.Bishop92t said:
Goes in between your oil filter and mount and is already pre-drilled for oil temp and oil pressure lines.
styin'ser said:idk if the threads and stuff are the same but this is available for my car. maybe it would work for supras too
http://www.courtesyparts.com/Merchan...Category_Code=
suprabad said:Question...are you saying drill a hole in the drain-plug and tap threads for the sensor? Come to think of it that kinda makes sense. At least if you screw it up it's just a drain plug and not a hole in you're block or oil pan or.....!
okeee dokeee
isnms said:what about here?
pic borrowed from GrimJack
IHI-RHC7 said:Is that electron blue pearl?
