oil squirter replacement
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
I'm putting together an itinerary for the "refreshment" (new crankshaft seals/oil/coolant gaskets) of my engine this weekend and I had a question about the oil squirters. I know that the TSRM indicates to install them when the crankshaft is out of the engine, however, can they be replaced with the crank in place? I haven't seen the 7M bottom end in a few years and I completely forget if there is enough clearance to remove them with the crank in place. I really don't want to have to mess with the rod and main bolts if I don't have to.
Thanks,
Adam
figgie
Twin Cities, Minnesot-ah
you can but you better have wobble extensions and about 2 feet worth of extensions too. That is the easy part of taking them out. The install them in....... short of a 3 foot needle nose pliar.
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
sounds like it might be difficult to get an accurate torque on the squirters that way...I guess I'll have to make a gametime decision.
sneakypete
Regular Member
Jul 18, 2007
1,129
Central NJ
thats not entirely true. i replaced mine during my build. with the crank in, they were a pain in the ass, but definetly doable. i did have the motor out, so i made it easier. you just need to rotate the crank for each one.
good luck
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
that gives me a bit more confidence...the motor is out of the car, and rotating the crank won't be a problem.
I really didn't want to disturb the bottom end...
TheNewRed
572
WA
Thanks,
Adam
I can let you know next thursday. i forgot to order my set, and its holding up the installation of my the motor and transmission. I have a 7M crank... possibly more difficult, but looking at it dosent seem too challenging?
jdub
Feb 10, 2006
10,730
Valley of the Sun
BlazIn TurbO;1131109 said:
i dont think they are but i could be wrong
This kind of comment does not cut it in the Tech Section...if you don't know for sure, do not post.
Neither the squirters or the bolts are aluminum. A magnet will be of limited use, unless it's a socket insert.
