the engine is at the machinist and i can't check, but do the piston oil squiters need to be installed before the crank/rods? i can't remember what order i disassembled it in, or if they were accesible with the crank installed.
IJ.;930067 said:Some people like to have all their ducks in a row before they begin....
starscream5000;930072 said::werd:
Better to ask then assume and make an ass out of yourself
jmanbball;930047 said:Surely, you did not need to post to figure this out. And if you did, you probably, shouldn't be building the engine yourself.
IJ.;930046 said:Easier before but can be done after.
Good idea to by new valves/bolts for them at this point as the springs can sag a touch over the years and this will affect idle pressure if they have.
