oil pump gear exploded today...WTF
aljordan
LEADED FUEL ONLY
Jul 14, 2005
466
Indianapolis, Indiana
www.apeserver.com
Nick M said:
While some 500 lb/ft isn't directly applied, much of it is. I suppose a little fatigue plus big ass torque eaquals boom.
I don't feel power isn't the problem here. i've been doing 500 lbs of torque for about 4 years or so. Something is binding in the shaft or the pump. The belt is still turning, and the force of the belt pulling on the gear shears it. It would be very interesting to have a place take a look at the gear and tell us what happened. I suspect that's realy the only way we'll find out the root cause.
One thing is for sure.. it sucks when it happens.
Stretch
Tallest MK3 driver ever!!
Toronto, Ontario
Ahaha thanks for finally proving me wrong someone. I just remembered some sort of gear being made out of billet for the 2jz that wasn't cam gears, so I figured it was this one. W/e make a billet one anyway damn it!
eric
Joel W.
Just A Jedi
Nov 7, 2005
1,561
Washington
If all the cracks were the same color, that would mean that it was a sudden failure..
Both of these guys said that the cracks were discolored which means to me that this gear has been weakened over time and it just finally let go imo..:)
aljordan
LEADED FUEL ONLY
Jul 14, 2005
466
www.apeserver.com
eric
That was a tensioner. Pretty sure it was for the serpentine belt.
A new gear would be nice. But I bet very expensive. Plus it doesn't solve the root problem. Just masks it.
malloynx
NC
i will post pics tommorow. i don't know how my driveshaft would seize up.. doesn't make any sense
aljordan
LEADED FUEL ONLY
Jul 14, 2005
466
www.apeserver.com
Nor do I. It's the only thing that makes sense.
I say put another one and let her fly. See if it happens again. Ensure your belt is done correctly as well.
Wouldn't be bad to ID common items that both of you (get that other cat in here too) have. Shaved head and block, blah.. blah. blah.
quicksilver
56
owensville mo
Same thing happend to me. I got to it intime that it just crack around the center section. I put another one on and it has been fine for over a year. I just contrubuted the failure to over tighting it when I put it on. I dunno...
pb92supraturbo
FTG & the IRL!
Aug 20, 2005
172
Garage, under Supra
I wonder how the timing belt was tensioned on the two cars that had the failure. Was the TSRM tensioning procedure followed when the timing belt was installed? If the timing belt was too tight, could the weak link be the oil pump pulley? The cam pulleys seem to be more robust in thickness and the tensioner is steel. Something to think about . . ?
