so.... let me just start from the begining....
i had it rebuilt, drove it for 500miles, took it back for an oil change....drove it 3000miles and changed the oil myself....when i changed the oil i also swapped out the old soft lines as they were leaking a little bit....
now i don't know about at the shop, but i used moboil non-syn 10w30[the clean 5000 stuff, but i still change at 3k] but after 3500 miles shouldn't i be good to use a modified oil?? i was told rings seat at around 500-1500 or never
but like i said i got this problem about...infact i think i would say since i changed the oil....
would help anything to ditch the oil and get a single weight oil??
at current i get blow by only when i get on it or blow off and it dosn't always happen either.
as for detonating, i run 93 and rich....although i'd rather have the problem fixed than to use octan booster....
is it possible to....pull the head clean the bores and put back together?? would do the pistons need dropped to correct this??
this really is some sand in my lube!! i was just over charged to have the engine rebuilt.....anyone with a good way out of this please speak up
IJ you've been very informative, but how bout some good news[thats not about the money you saved on your car insurance]
john
