i have a small crack in the line that comes off the valve cover to the oil pump doesn't leak oil but could it be causing drops in dramatic oil pressure
Preventative maintenance for his BHG.jetjock said:Fascinating. I suggest you take the car to a mechanic and afterwards have the hood welded shut.
kayledao said:i thought that the oil pump put oil thru this line i guess i was wrong not the first time but what then would cause the loss of pressure at idle
