I got the idea from the 7m assembly tips thread by Adjuster:
http://www.supramania.com/forums/showthread.php?t=5631
I would drop the pan but i'll have to borrow a hoist so it will be a bit. In the meantime i'll check the oil cooler relief
Now you can set the depth of the pickup if you want. Measure the depth of the pan with a straight edge and tape measure. (Pan rails to sump depth.) Then measure up from the block rails and see how "low" your sump sits. With a careful hand and a pry bar, you can gently bend the sump "down" up so it's sitting lower in the pan when everything is together. This might make the sump slightly crooked, but who cares, it's now lower into the oil that will keep the engine alive longer. If you go too low, it will starve the motor however, so about 1/2" or 1.5mm is a good call. Keep in mind the screen is not the bottem of the sump pickup, so if the screen is almost touching, it's about right.
