could i use the feed for turbo oil supply from the block as ive gone for a single turbo conversion? basically just use some braided hose with correct fittings and remotely mount the oil pressure sensor...
It's much easier to use the stock location, it has the signal wire there and all..just buy the aftermarket oil pressure adapter that driftmotion sells...done:icon_bigg
i would idealy use the stock location but its a PITA to get to hence im looking at an easier solution... as im going single one oil feed outlet would need to be blocked anyway!
