oil pressure gauge installation
umran9
15
UK
could i use the feed for turbo oil supply from the block as ive gone for a single turbo conversion? basically just use some braided hose with correct fittings and remotely mount the oil pressure sensor...
thanks umran
Gritz
155
nc
thanks umran
It's much easier to use the stock location, it has the signal wire there and all..just buy the aftermarket oil pressure adapter that driftmotion sells...done:icon_bigg
umran9
15
UK
i would idealy use the stock location but its a PITA to get to hence im looking at an easier solution... as im going single one oil feed outlet would need to be blocked anyway!
Gritz
155
nc
yeah i keep forget im my not running any power streering on my 260z swap..
tissimo
Stock is boring :(
Melbourne, FL
thanks umran
Yes you can.
