rayall01;1358919 said:How about illogical?
He got his point across - don't drag this thread off topic grammar nazi...
cobbeh;1358786 said:I guess I'd better just come out and say what you already suspect. I am fairly new to all of this. I've done minor work to my car with the help of more knowledgeable people.
I'm right about due for an oil change. The car has 111,000 miles on mostly original parts. My last oil change was maybe 108,500. Unfortanutely I live in an apartment and don't have my own garage so I used a shop to change my oil last time. I don't know what brand/weight was used. It just recently had the head gasket replaced but it's got a lot of old hoses I've been replacing. The guy that owned it before me kept it very nice in a climate controlled garage in New York.
I didn't have my head on straight when I first got this car. I was always under the "drive it like it was meant to be driven" mentality and didn't take the best care of my car during the first two years. I've since rethought everything and have been trying to take it easy. Trying not to drive it into the ground. I'm trying to do most of the maintenance myself but I live in an apartment and do not own my own garage. It's difficult for me to get anything done in the Florida heat.
There are a couple things currently wrong. The engine has a slight hesitation that I'm told is due to an intake leak. I replaced the hoses from the MAF to the turbo/throttle body... but I still can't find it. The turbo hesitates a little as well probably due to the same problem. The clutch is starting to slip and of course the oil pressure problem.
Sorry for the essay but I thought it might help to better understand the idiot you're dealing with![]()
Ok, so we've got:
When was the last oil change (how long / how many miles ago)? 2500 miles
What oil was used? Unknown
What filter? Unknown
What's the age of the engine? 111,000 miles
What's the overall mechanical condition? Good
Any ideas on how this car has been maintained over the years? Sounds like it was well maintained, but suffered about 2 years of "hard use"
With all that said, #1 - eliminate the unknowns.
Choose a good oil. This will help:
http://www.supramania.com/forums/showpost.php?p=533980&postcount=1
Keep in mind where you drive the car. If you stay 100% in Florida, you can work with slightly thicker (German Castrol 5w-30) oils. If in doubt, ask Jdub for a specific recommendation. I'm going to shoot him a link to this thread to double check me here.
Don't be afraid to switch to synthetic oil (that first link will tell you what synthetic oil is an isn't):
http://www.supramania.com/forums/showthread.php?t=49245
Run one quart over the full mark on the dipstick. (This is usually 6 -/+ quarts in the 7M-GTE)
Use a good filter:
http://www.supramania.com/forums/showpost.php?p=589060&postcount=2
Personally I'd suggest a Wix or Purolator PureOne
Once you have those things settled, you are on firm footing. You know what you have, and our ability to respond to you will be enhanced quite a bit.
Overall, from what you're describing, there may not be anything wrong with your oiling system other than normal 100K wear.
How recent was the head gasket change?
Address the unmetered air leak. It shouldn't be that hard to find/fix. That can cause detonation, which can put you right back in blown head gasket land.
