Oil pickup gasket
steveyblack
529
Nj
Is it ok to use FIPG on the oil pickup tube gasket? I think there is a stock metal type of gasket, or should I use that instead?
steveyblack
529
Nj
aphxero;1337993 said:
o-ring dawg.
When I took off the front sump pickup out of my 2jz there was not a o-ring, There was a thin metal gasket. I dont see how a o-ring could fit on the pickup
pbasil1
Fully built 1JZ project
Jan 30, 2008
402
Huntsville,AL
I dont either... There is nothing for the O-ring to go around.
I used gasket maker for my pick up tube... I think it will work out just fine.
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
This is a risky spot, don't use RTV, if you have any leak, even a pinhole leak you will suck air into the system and last time i checked air doesn't lubricate very well. Get a Toyota gasket and never worry about it again.
steveyblack
529
Nj
ya ill just go oem
