so now, along w/ all of the other problems, my oil pan gasket has sprung a leak... any advice? the gasket's never been removed... god just hates me, and all of the bolts are tight
brad92t said:FIX IT!! PULL THE MOTOR OR DROP THE CROSSMEMBER THIS WEEKEND AND FIX IT
i didnt and i paid for it with rod knock. mine was leaking like it had a HOLE in the pan.. and i was too stupid about supras at the time to know better. now my engine is out and i am in the middle of a complete rebuild! then again what better an excuse for building up a supra motor than rod knock! :biglaugh:
anyway, there is in fact a gasket on there and it is in fact cork. i was told by curt from elmhurst toyota the same thing, that there is no p/n for the gasket and to use sealant... but sure enough i pulled my pan and there is a cork gasket on it.
i would use the best sealant you can find... cork sucks.
figgie said:no there isn't
see the link i posted?
that is right from the TOYOTA Service Repair manual, There is in fact NO CORK gasket, it is RTV sealant.
brad92t said:anyway, there is in fact a gasket on there and it is in fact cork. i was told by curt from elmhurst toyota the same thing, that there is no p/n for the gasket and to use sealant... but sure enough i pulled my pan and there is a cork gasket on it.
daledoe said:I see what figgie is saying it dos sound like you are saying it has one stock!!!
MDCmotorsports said:All the "gaskets in a tube" that I have used for an oil pan have leaked.
The cork works great, its just it has to be torqued and torqued correctly or it WILL LEAK.
Any thing over 5 ft lbs is kililng a cork gasket.
