Oil pan gasket? or Permatex? lol?
lagged;1138648 said:
FOLLOW THE TSRM.
if you follow it exactly, your oil pan wont leak.
this includes checking the oil pan sealing surface for flatness.
be sure to follow the proper torque sequence and it wont leak.
Key point there. If it's not flat, it won't seal.
It's VERY sticky ;)
It's a bit hard to quantify it just seems to work better than the alternatives and I've never had a leak using it, having said that it is a PITA to remove once cured.
(I could easily run my car with no pan bolts once it's gone off)
that 3bond stuff is very interesting. but fipg itself is still very good stuff and holds up for a very long time. dont use a cork gasket it was never intended for this car and sealent works much better. even old chevys use sealant around the front and rear mains and then cork on the sides and the sides are where they leak mostly!
92TealSupra
Supramania's Parts Man
Sep 2, 2008
1,584
Great Lakes State
Loki;991093 said:
I've sealed a few oil pans with Permatex The Right Stuff, and never had problems with leaking. I've also used the Toyota FIPG, the FIPG has a better shelf life once opened then the Right Stuff does.
I heard this is great, my schools' Mustang uses this and our teacher says this is a fantastic product, our mustang never leaks oil.
Remember to follow directions...
You're supposed to let the sealant set for a bit and then put the pan on, can't tell you how many times I've seen people get leaks from not reading directions...
92nsx
2,957
Clearwater, MN
My engine builder used both (I hope it never leaks, I HATE LEAKS) cork gasket (Felpro) with FIPG on both sides of the cork.
WhtMa71
D0 W3RK
Apr 24, 2007
1,813
Macon, GA
Id did that the first time i stuck my motor in and it leaked pretty good. Didn't leak at first but after a few weeks it started leaking. Left black spots all over the driveway..Sucks having to take the motor out of fix the freaking oil pan..
May 18, 2007
704
Aarhus
I found a gasket on german ebay. It is made out of thick oil resistant rubber - not cork.
Maybe I'll use that together with the liquid stuff.
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
IJ.;1142008 said:
When I had my old 3.4L Toyota V8 they had a steel shim pan gasket that was covered in rubber, THE BEST pan gasket I've ever used period! :)
agreed, i bought a similar one for my tundra and all i can say is wow.. it was not cheap but you know it will seal heh
