Oil pan gasket? or Permatex? lol?
FlikRacing
93
Michigan
Alright, Iv been told both, " use the cork gasket " " No don't it blows out " Well I am not sure, iv heard people say use the permatex, it was intended for that, well I want the real answer before I do something stupid. id rather do it right now then later thanks.
teedoff00
14 psi boost
Dec 5, 2007
297
Selah, WA
I used Toyota FIPG, which is black "oil resistant" RTV, it runs like 14 bucks a tube. Cork gaskets didnt work well for me, always breaking and squishing out the sides, etc.... Just use RTV...
Loki
The Future is Unwritten
Prince George, B.C.
I've sealed a few oil pans with Permatex The Right Stuff, and never had problems with leaking. I've also used the Toyota FIPG, the FIPG has a better shelf life once opened then the Right Stuff does.
May 18, 2007
704
Aarhus
I'm gonna use this thread since it almost covers what I want to know.
I had my engine rebuilt last december, but ever since I have had a minor oil leak, which seems to come from the oil pan on the passenger side.
We are going to fix it next week, but I would like to know if I should put a gasket in there or not.
The TSRM says no gasket as far as I can see. And reading this thread I can see people just using sealant.
I was wondering if the fact that my pan is leaking after using just the sealant would change this recommendation? The guy who is going to help me reseal the oil pan tells me to use a gasket this time since just using sealant on an old previously leaking oil pan is just asking for trouble.
If I should use a gasket this time, where do I get one? Does Toyota make one?
Suprafast0422
107
Maryland
make sure both surfaces are clean and dry and sealent will work just fine. I myself just use fipg on anything that calls for a sealent because i work at toyota and get it pretty cheap. Interested in this 3bond stuff though, is it just easier to work with then other sealents or why do some of you like it better then others?
lagged
1991 1JZ
new rochelle
FOLLOW THE TSRM.
if you follow it exactly, your oil pan wont leak.
this includes checking the oil pan sealing surface for flatness.
be sure to follow the proper torque sequence and it wont leak.
