oil journals on crank
webbs7mgte
298
wisconsin
i measured them today and does it make sense that they are larger than the TRSM size? do you think my micrometer may just not be set at a negative number? also what does a 7m crank go for now a days looke donline and there asking 750 so if i was to sell mine i would have no idea what to ask
gaboonviper85
3,236
Northeast Philly
your mic should have came with a gauge aka "standard" to set it.....or you are using the wrong mic....
what make is your mic? mics dont just go wrong...either you are turning it too hard or you droped it....
to use a mic proper just spin the dial very very very lightly and wiggle the mic around the part untill the slightest pressure doesnt turn the spindle anymore...that is your accurate reading...when i use mics i use 1 finger very gently to spin it.
im a machinist and our shop standard is .0003"....very very tight tolerance shop as we are iso9001 certified....
i think your doing it wrong.
