Piratetip;1234465 said:Did it feel like a shit laden diaper?
New oil filters are very lightweight.
You should easily be able to tell if there is any oil in it.
to freaking funny!! ::focl::
jdub;1234172 said:RPS - Is there any oil inside the inner tube at all? Did you cut the outside case off the filter to see if there was any oil on the outside pleats?
Reason I ask: Toyota OEM filters have the bypass valve on the dome end...if it is stuck, it will allow oil in the outside chamber then exit out the center hole, but not through the media. I'd cut the filter open for more info...sounds like (since you had oil pressure) the filter bypass was functioning.
If the filter head cooler relief valve was stuck, you would have noticed a significant drop in oil pressure.
grimreaper;1234475 said:to freaking funny!! ::focl::
CyFi6;1234504 said:Ah, i thought we were talking about the cooler relief. Even if the filter bypass valve was stuck open there would still be oil in the filter, i think the original poster is mistaken when saying its completely dry, doesn't really add up. Maybe you picked up the new filter by accident? lol
