Oil Filter Relocation Kit/Cooler Setup(Assistance)
OneJArpus
2,798
Hi all, i need some assistance making a complete oil cooling/relocation kit. I know there are alot of threads but i want to know what i need exactly. This is going into an 88 1J Supra.
Oil Filter relocation kits:
http://store.summitracing.com/partd...&part=PRM-10795&N=700+304357+115&autoview=sku
http://store.summitracing.com/partd...&part=PRM-10695&N=700+304357+115&autoview=sku
Coolers
http://store.summitracing.com/partd...part=BMM-70272&N=700+-128262+115&autoview=sku
^not sure if i want to spend 100 on a cooler... any ideas?
Not sure what size i should get. Thickness? Legnth? Height?
Thermostat
http://store.summitracing.com/partd...&part=PRM-1070&N=700+-128262+115&autoview=sku
Hydro Fan cooler
http://store.summitracing.com/partd...&part=PRM-1004&N=700+-128262+115&autoview=sku
P/S Cooler
crazysupra2JZ
740
Georgia
use your stock oil cooler, if you had a 7MGTE. make sure there is nothing clogging it. i still have mine if you don't have one. PM if you might be interested in it. just pay for shipping and the paypal fee.
crazysupra2JZ said:
use your stock oil cooler for the power steering as that's all it's good for, if you had a 7MGTE. make sure there is nothing clogging it. i still have mine if you don't have one. PM if you might be interested in it. just pay for shipping and the paypal fee.
Fixed ;)
fstlane88
Single time!!
South FL
The kit I'm using...
http://store.summitracing.com/partde...5&autoview=skuand the cooler I'm using, Suprasport.com doesn't have on their site any longer. It's an Earls similar to all the units Summit has, it's not as tall as the one you posted but definitely as wide and about 2" thick. I have it mounted in my DS foglight hole, going to be adding a PS cooler in that same area. The filter I have mounted in the engine bay just behind the sway bar, with the filter pointing down, I need to move it though, b/c it's just a little too close to the sway bar for my liking.
HTH,
~Bryan
EDIT: Actually that oil cooler you posted looks almost exactly like my trans. cooler. Except it's black.
fstlane88
Single time!!
South FL
I'm not sure who your question is directed to but I have mine mounted up and it fit perfectly, the kit has several adapters which made it easy. I would definitely suggest doing this install before you drop the motor in, I'm sure it could be done with the engine in the car, but won't be fun.
It'll be about as much fun as moving my oil filter is going to be b/c I have no idea how I'm going to get a drill in there.
TurboToy-R
120
Duncan BC
Before I drop the motor in? PSSHHHHH, my car's JDM :biglaugh: But ya, I'll have a fun time getting that on there, but will be worth it.
