Oil? Does anything really bad happen if you have the oil level above full?
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
You'd be perfectly fine with 1.5 quarts over full. How far over full can you go before it becomes an issue with the crank dipping into the oil, causing PCV problems, etc.? A Lot.
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
Like I said, A LOT ;).
It would really be a waste of money to go anything over 1.5 quarts extra, unless you were running two extra large oil filters with a big ass oil cooler.
H-Dogg
125
Watertown, Wisconsin
Yeah, I really didn't think anything would happen. I just changed my parents oil and they freaked out cuz it was like 1 quart over!!! So, they made me make sure nothing would happen.:3d_frown:
mkIIIman089
Ohio
So... you screwed up an oil change. PLEASE, don't touch the Supra.
AGlobalThreat
Acceleration
Apr 4, 2005
991
Santa Clarita
Too much oil = mo pressure = mo leakin sealz yo.
I overfilled my oil, started a drive, 5 or so mins later the oil pressure peaked the stock guage high enough that the needle fell off the center and the car was smoking and running like ass. I had to drain a lot of the oil out and let it sit and eventually the car was running normal again. On the 'ol GE of course.
AGlobalThreat
Acceleration
Apr 4, 2005
991
Santa Clarita
20w50 :\ . I don't remember the name but it's the same kind I always used from the local auto parts store (Not Autozone, these people actually know their stuff). I don't think that was the problem as much as the fact that I overfilled by over a qt. iirc. It was a while ago lol :)
BJ91T
810
Baton Rouge LA
hmmmmmm I filled my car with 6qts on a bone stock oil system minus the driftmotion oil pump crossover tube and i have killed 4 rear mains now and i think my current one is leaking. The problem may have calmed down a little when a istalled a larger catch can I wonder whats up with mine???
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
I think that has a lot more to do with running a thicker oil than you would ever possibly need in a 7M versus filling it one quart over full. Maybe you should browse jdub's SME section? ;)
Ummm just HOW does more oil = more pressure and leaking seals?
(a hint here is there are NO seals in a 7M under direct pump pressure)
+1qt hurts NOTHING my guess is a modded PCV system.
8,894
Got to love people that just pass along bad info because it sounds technical, eh IJ?
20W/50 for the win!:eek:ffwall: :ugh2:
jdub
Feb 10, 2006
10,730
Valley of the Sun
Yep...got a thread on this exact subject (using a 20W-50) in the SME section. Over filling by a quart will in no way cause leaks...neither will running a 20W-50. Like IJ said, there are no seals in the motor under direct oil pressure. Not a big fan of running thick oils, but for other reasons ;)
bountykilla0118 said:
Hey hey ..... You leave my 20w50 alone :) where is my buddy jdub :evil2:
He has tricked me into using lighter oils
LOL...:evildeal:
