IJ. said:B&M do a few Kits that have hoses adaptors and a cooler in em, add a T Stat to that buy the NA Filter stud and you have a bullet proof Oil system!
ok
appreciate it.jdub said:That's exactly what I did...AN8 stainless hose w/ AN fittings on the cooler...had to use the slip on hose clamp type on the stock hardline side.
shaeff said:11x8 B&M cooler, 180* B&M t-stat.love it. mounted it to the coolant resivour bracket, and center support. gained +20psi on cold start, and +20psi at cruise. i also relocated my oil filter to near the passenger side tow hook, and the filter is about 2.5-3x the size of the stocker.
-shaeff
