I've just installed an A/O oil cooler and oil filter relocation kit.
I put the oil cooler after the IC,between the IC and the condenser cooler.
I do see a 5-6 degrees Celcious drop in oil temps during normal cruising,
(haven't raced the car yet) but I do see about 5-6 degrees Celcious
increase in coolant temp.
Is that....Heat transfer issue from the oil cooler to the radiator?
Have the stock oil cooler on the 2jzgte,with new radiator,stock fan,new
thermostat,rad.cap. Going to install a spal 600 cfm fan infront of the
condensor and after the oil cooler to push some air through the condensor
to the radiator.I am also waiting a sard 72'C thermostat and a blitz 1.3 bar
radiator cap. I think these will help a little...
What else can I do? Any ideas...?
The oil cooler won't fit elsewhere,that's for sure..
