oil breather question
Clip
The Magnificent Seven
Oct 16, 2005
2,738
9
Virginia
same, my value keeps goin down, but after everything is brand new again, i expect it to rise ever-so-slightly. id go the jdm route on the charcola (yes, charcola.) can and leave it at that.
IHI-RHC7
"The Boss"
Oregon
Hmm, you seem to be in a big hurry to sell your car, Gary...
About the BPV venting issue...
The engine breathes through the ISC at idle. All bov's open it idle, that's how they vent, vaccum in the manifold opens them.
The reason it doesn't matter is that there is no airflow in the pipes at idle.
If the valve is an old pos, it will stay open once the throttle plate is cracked, and then you run into injesting unmetered, unfiltred air, which is bad.
Solution, fix the valve...
