Hi all, occasionally my car has a noticeable ticking/knocking sound at idol after the car has warmed up. I originally thought it to be the AC compressor or the PWR steering pump. I removed the AC comp belt and found the bearing was bad in it so it was making a sound but the ticking/knocking sound was still there. I then moved on to the PWR steering pump, I noticed something really weird with it though, the belt flipped over and it was chewed all up, I replaced it along with the ALT and water pump belt and the ticking/knocking sound still persisted, and it seemed as if there was another new ticking sound coming from the intake side cam.
That was two days ago, I just took the car out tonight and it was running great, better than has in a while, it really seemed that it had more pep, and when I returned home the I couldn't hear the ticking/knocking sound anymore, I don't expect anyone to have exactly what the answer is, but any idea on where to look if I hear it again would be helpful. By the way, the car has a mid-low mileage JDM engine in it, I just changed the oil to a weight of 10-40 two weeks ago. It has had a occasional very small miss in it for a while as well, It can barely be heard or felt, could that have contributed to the ticking/knocking sound, and could the ticking/knocking sound be caused by something with distributer? Like I said, any advice would be helpful, Thanks!!
