o2 sensor q's
shiftysupra
180
Tucson, AZ
So I purchased a jdm engine and it came with a rhd harness. The engine harness I am currently using is a 91' targa auto harness. My question is what terminals (or connector) would I rewire the 02 sensor to? The one that is connecting to the o2 sensor is a round grey plug and the inside is sort of a triangle shape... it has 2 black and 1 blue. I know blue connects to OX terminal and one black one connects to E2 for the ground but where does the other one connect to?
also on the harness in my car now, have a squarish type plug with 3 wires as well. has a white one and 2 pink and blue striped ones... would that be the o2 sensor plug?
I am throwing a code 51 and 34. I know 51 is the tps connector which I did test and is bad. And the 34 is a boost leak issue due to me not being able to find the correct size coupler reducer for the turbo outlet and it keeps popping off...
anyways thanks in advance:naughty:
CajunKenny
PULL MY FINGER. PLEASE!
Nov 15, 2007
3,255
Washington
Cut and splice baby. Cut and splice... :)
Oh...either connector will work. I'd just pick the one that's in the best shape and use it.
