shaeff;1190065 said:^ Alcohol also burns much cooler than gasoline.
adampecush;1190379 said:and aluminum melts at 1220.58F...just a tad lower than copper...
Figgie, by your logic, the head should be melting away as time goes on...which it obviously doesn't. If you are heating the copper to the point where it melts, you have some serious cooling system problems.
figgie;1190397 said:Please don't assume to know what I am thinking or even worse interpret something I typed to something that is not there, But since you insist (and I am really in a great curb stomping mood today).....
figgie;1190397 said:Pure Aluminum does. I would love to see just ONE head which is pure aluminum. On ANY car at any price range to include F1 engines. Yes sherlock, that means 99.9% PURE. Hell, just for this I will take 95%.
figgie;1190397 said:While we are on the subject of "by your logic" as you so eloquently put it,
By YOUR logic, that is why copper spark plugs last 200,000 miles without changing! Man I knew those spark plug manufactures where brilliant but that simplistic an answer eluded me until you showed me the light!
adampecush;1190406 said:ah, the ninja edit...you and I both understand why copper plugs don't last...comparing spark plug wear to the HG is comparing apples to oranges.
Poodles;1190432 said:Aluminum alloys melt at higher temps is what he's getting at (though he could have been a bit forthcoming).
Pure aluminum is too soft to do much of anything with.
figgie;1190415 said:Apparently you don't.
Even you said it, Cu has a higher melting point than Al yet the copper goes away and the Al stays........
maybe in your eyes it is not the same, they are infact the same and part of the same system. The issue at hand, which you do not seem to comprehend, is the very thing that makes my statement above correct.
IJ.;1190511 said:I was under the understanding that "Copper Plugs" were only Copper core I don't believe for a second that the actual electrode is copper or it'd last hmmmm 5 revolutions
figgie;1190470 said:4U2
Aluminum 6xxx series and 7xxx series still lower than 100% pure copper by about 800 degree F.
The "magic" happens in the none-combustion chamber facing portion.......the water is what keeps the head from becoming a molten puddle and yes, without coolant the head would start to become extremly warped, become annealed and ultimately, melt. That is exactly why ALS is so bad on turbos as the temp reach 2000f when the combustion happens so late in the process. But yet the Al head is still good. Regardless of what has been said here. Copper for HG in a daily street driven car is nothing but pure and simple studidity UNLESS you want to pull the head on an x mile or y hour basis. Goes along the same lines of the "EGR is bad" bullshit that was propagated for a while.
As for the berylium-copper. There is a reason they use beryllium copper valve seats with Titanium valves as it is still soft enough to have some give and not chew the Ti valves. Shame about the cost and machining hazards.....
4U2QUIK;1190551 said:i was going off of my head, I don't actually have any reference material here at home. my bad.
as for machining berillium copper, it dosen't have the same hazards as berillium. Something about the copper takes the danger of Berylliosis.
