O.E.M/Factory .05 over pistons 7mgte
jkbmkiii
539
Castle Rock colorado
Anybody have any information about 7mgte O.E.M .05 over pistons.. The piston is stamped .50+, so Iam not sure if it is a .50mm over(.02) or .05 over?? I guess if anybody has a link for something like the sale of these pistons I would like to take a look, need info!
jkbmkiii
539
IJ.;975145 said:
Stamped .5 would be half a mm or +20 thou.
The reason I ask is that Toyota keeps telling me its a .05 over, yet I cant seem to find any pistons for sale that are for a .05 overbore, so I keep telling them they are wrong and they just return the gesture!
jkbmkiii
539
Does anybody manufacture a piston with that large of a bore?
Iam trying to get all my information straight before I put the short block up for sale!
jkbmkiii
539
IJ.;975178 said:
Yep correct but as always physically measure them to be 100% sure!
(the machinst should do this before touching the block)
All is assembled just making sure I know what I have before I look like a liar trying to sell it!!
jkbmkiii
539
IJ.;975196 said:
Ahhh I see!
Should be a +20 thou motor then! :)
This is the engine I made 350whp and 360ftlbs tq @ 11psi with, just did not know if a .05 over bore attributed to the awesome dyno #! Guess not!
I guess the balancing helped!
jkbmkiii
539
IJ.;975210 said:
LMAO even the biggest oversize will add very little capacity to a 7M ;)
(hence power)
I'd put your numbers down to a good build with correct specs :)
I had this built before I new about SM:3d_frown:
Expensive, I could have built a forged engine for what I payed back in 99 for this one!
