ok, i just changed the oil in the car cause if there was water/condenstion i know that could end up bad... the oil look alright when i drained, just dark brown. IJ. iam going to try your suggestion believe me.. im just in a tight pinch cause im moving this morning to Indy. as soon as i get settled in im going to try all these suggestions. i just knew fresh oil was a must and its all i had time for. as for the coolant lose, it seems to no be losing NEARLY as much as before, i think before it still just had alot of air pockets we didn't get out. i'v been talking with jeff (boost lee) he said when hes CT turbo started going bad he had the same problems, fould spark plugs, loss of coolant, and he had the milky crap in the oil. he replaced his turbo and problem was solved. and my car has the exact same symptoms. iv done compression tests and the compressions are all good. only thing that makes since to me is the turbo. last time i had BHG my oil turned completly green from coolant and my water pump also went bad. i dont have any of those symptoms. im not a stupid person, some times theres just reasons as to why i cant imediatly jump on your suggestions. life happens you know.
