Nor-cal supra peoples help!
suprastroker88
Supra Tuner
Jul 16, 2008
453
Bay Area, CA
Zumtizzle;1081425 said:
Hmmmm.
Define Leaking HG?
How complete is the NA-T conversion?
I'd avoid putting a MHG on a motor with Cast Pistons.
If you want a Running NA-T. Do a compression and Leak down test. (Most of the time the rings on the NA motor are fine due to lack of hardcore turbo blowby)
If you want someone local to you. I recommend Karlo/KBR (Vallejo). Very nice guy and no BS. He has built a ton of supras, and won't bullshit you and will get you set, right.
If you want his phone number send me a PM.
I think Rennat's gona rebuild it for me. But if he doesn't then I will definitely take you up on that. Thanks
